Below are pictures of the start of construction to extend the EVWR branchline to it’s west end at Okawville…
The first thing on the agenda, was to finish out the retaining wall that went behind the Mainline and siding for Addieville… That wall is the brown stack on the left side…
At the end of the brown wall, there will be an area for water drainage from the hill, to get down to the waterways that run downhill, under the Hilltop Subdivision…
The first bit of excavation was to establish the line for the retaining wall that will be behind the Okawville Mainline, sidings and elevator…
Once the base line was established, then I proceeded to cut out the area for the elevator and sidings, to be filled in with a solid base of ““aglime”” for the roadbed…
Below is a picture of the retaining wall being constructed.
This area is for the drainage off the hill… This area will be covered in ground cover, then topped with rock… The tracks at the base, will be a single track curved trestle that will allow the water to flow thru…
That is pretty much the extent of the work completed by dark, Sunday evening… Actually, a bit more of the base wall was completed, and most of the dugout area was filled in with aglime, but was too dark to take more pictures…
Okawville will have a mainline, a branchline siding, and the elevator there will have 2 sidings… The mainline and branchline sidings will be along the edge without the retaining wall… The elevator and sidings will be behind that, running up to the retaining wall… Entrance to the elevator sidings will be from the end of the line, as it actually is IRL…
I dug the H beam out.
