In the obsessive, so my wife says, quest for ever brighter headlights, how do ya figure this will come out? Pennsylvania Big Hauler is test subject.
Back was removed and number boards were opened out for adding clear part. LED will be attached to back wall of headlight. Styrene disc for back wall with .060 spacer holding light forward. Probably use 1000 ohm resistor off track power.
The less satisfactory presently in use 5mm warm white led behind stock lens will become backup light, stock was unlit. Yes, these are 2 different light castings, one was grey plastic, one black, on the same loco!
