OK Shay No9 came out for her first run of the season and went flat … at first I thought perhaps it was faulty batteries, so I swapped 'em out…no luck. No9 is a 4 truck Shay, with the front three trucks powered and a Sierra Sound system. Power is provided by 12 NiMH 2800 mah cells. Control is viathe Action RC EVO system. When at rest and turned on , the locomotive lights and sound comes on and everything is normal, then when the locomotive moves, things start happening. Operation is jerky and the sound begins glitching exactly like when the batteries are going flat.
Do I have a short? Wheres the most likely place? Anything else I should check out?
