Jon,
This being my first pin nailer, I can say that it was not as noisy as I thought it would be and I had no trouble moving it around the engine shed. It’s not too heavy, and it has a double trigger to prevent misfires and the safety trigger turns on a led light.
I think my only significant disappointment was finding out after the purchase, that would not be able to fire my recently purchased 8 & 10 mm pins. So I have pins sticking through the other side of my roof’s beams. I suspect I can clip the pins off or pull them through once the glue is dried.
Ironically small corded pancake compressors are not sold in Oz. However , as I passed through Bunnings (= your Home Depot) I came across a dewalt pancake compressor and thought that I could have gone pneumatic. However it provided the worst of two worlds, the inconveniences of a pneumatic hose and a limited battery power supply.
I have 4 different brands of battery operated tools (not that I wanted it to end up that way). Dewalt 10.8 volt, Milwaukee 12 volt, Ego 56 volt and now RYOBI 18 volt.
Jon, I don’t know how inconvenient it is to have a trailing pneumatic hose, but if someone made a corded lighter pin nailer, I would have had considered having a look. I only mention this as I’ve found I need 2-3 batteries on charge for other projects around the house and sometimes the corded versions are more versatile or robust. I certainly would have preferred to not be running 4 different proprietary battery systems.
