I have an overhead track in a small 12 X 30 Hobby Room. The first track I put in using Aristocraft sectional 8 ft dia. curves. I’m adding a second set of tracks. I hand spiked several 6 ft sections of track using code 250 rail and handmade wooden ties. When I try to bend one of these sections using a rail bender I get irregular results. Most of the ties get skewed so they are at angles to the track and do not hold it in gauge. The ties aren’t connected to each other like flex track is. Is there a way to make this work or will I have to bend the two rails separately then spike them onto the ties.
Harold Wilson
