Shortly before this all went to hell in a handbasket, I picked up a soldering iron in hopes of making things light up. I had picked up an Aristo switch-tower at the end of last fall that had wires snipped and original lights removed. Fortunately, in that estate, most of the parts were there to get it close to original. I spent yesterday evening re-wiring and lighting it up.
After getting the light glued, I secured the switch-box.
Finally, put the roof back on. I’m not sure if I’ll re-wire the smoke unit or set up a flickering burn-barrel down on the base.
