Hey there. Current time seems like a decent time to make progress on projects which have stalled or gone dormant or been set aside to do other projects in other genres.
As part of the overall scheme some more detail parts ordered via Ozark Miniatures arrived in today’s mail. ![]()
The other day it became necessary to repair a breakage on the V&T 4-6-0; somehow, the retaining pin for the main rod broke ![]()
Fortunately, the is the hulk of an ancient battery-powered Big Hauler from which to strip parts, the purpose for which it was acquired.
Also in progress, again, are some boxcar scratchbuilds for my freelance Willow Creek Traction line.
Construction was started when I was a poor man and couldn’t buy new materials specifically for such a large project, so they are a mix of basswood, balsa, and matt board.
They will have the typically lighter weight look of interurban boxcars; a look which includes a shallow arched roof with rounded ends.
After several years of pondering exactly how to construct the roofs I decided to raid the balsa planks stashed for making a couple more rubberband powered submarine models since they will likely never get made at this point in my life. Wood will be glued to roof base then carved to shape.
Am pondering covering the fairly soft balsa with something & I still have the light fiberglass from an un-done RC boat project of a decade ago. Would probably need to get new epoxy/resin though.
Also for WCT are some cars which will look like battery trailers sometimes used on mine electrics or industrial electrics - they will provide additional pickup points for the HLW Sparky with its 4 wheels.
EDIT: Oh, guess it might be relevant that the contact wipers are from Bachmann Big Hauler coach kits bought in 2009. They are flattened and tipped on their sides to contact wheel backs: on B’mann cars they went vertically between wheels on truck in an inverted V to contact rims of wheel flanges - in practice they made more efficient brake shoes than electrical contacts.
V&T Big Hauler is getting its firedoor cut out so as to make a thing and install flickering fire effect lights. They would look grand reflecting off the fireman figure at night as he tosses another log in to the firebox.
