Here’s hoping someone out there there has dealt with this before me. One of my BBT drives has a motor that is loosening up from Barry’s motor mount. The motor mount is fastened to the channel stock chassis, but there’s something else going on that is preventing the motor mount from being removed. I can’t see any other mounting screws or anything else. Does anyone out there know how to pull the motor bracket out of these drives?
I havent looked at my BBT drive for a long time so I can’t be sure.
Having said that, the factory Bachmann drive on the stock frame has a steel pin
driven through it that holds the motor in place. I don’t know if Barry kept that feature or not.
You got it right, John. All I had to do was move the wheel to see it. Thanks.
It turns out the BBT drive has a set screw instead of a pin, which made the fix super easy.
This is what I love about the people on this site. Someone has a question about an item no longer supported or available, and within an hour, it’s solved.
Now if, with that supposedly FRIENDLY Spirit, we could see young Bob McCown visiting the Chat Room once in a while…it might be a pleasant experience…
Fweddy
