Steve Featherkile said:
Stan, were you able to use one ESC and one battery to power your ABBA? What did you use?
Steve, Yes, one receiver and one battery. I tried the regular REVOLUTION receiver and it worked for a while but it would overheat or overload with a long consist and shut down. It was just one of those “experiments” that I tried working with the REVOLUTION.
I changed to the REVOLUTION track side received in the battery car and yes, used one battery… If I remember correctly, it was a 14.8 Li-ion 6600 pack from All Battery. It worked just fine when the ambient temperatures were in the 70’s and low 80’s. With higher temperatures, I had to remove the roof from the battery car to allow air flow to cool the receiver and battery. All 4 units were powered and wired together. We took them to Marty’s to run on his layout. I was quite happy with them.
However, now the layout is gone, we’ve moved into a Senior Retirement Community and are living in “memories” Sigh…
