My battery powered LGB Forney has An Aristo Revolution system wired directly to motor with two Li_ Ion 11.1V 2400 mah batteries for power,sound unit is Phoenix’s PB-9 . Engine will run at least 3 to 4 hours before it needs charging and can pull 7 to 8 pulpwood cars up a 4 % grade . Working on converting my other two Forney’s to same sytem.
Paul,
I have a couple of those as well.
Prolly the most reliable loco LGB produced.
I call them my “Mini Mason’s” (Mason Bogey)
I’ve only converted one LGB Forney. I put 14.4V, 4.5AH NiMH batteries, an AirWire receiver and a Phoenix P-5 in it. It certainly fills up things.
HI all,
It’s great to here that other’s have discovered that the LGB Forney can be the workhorse on any railroad,super reliable add battery power and you got yourself a winner.
I have enclosed photo’s of the inside of my Forney so you can see placement of Aristo’s Revolution,Phoenix’s PB-9 and Battery setup hope this helps.Feel free to e mail me off line for more info
Hi Terry,
have put photo’s in my file for you to see
Terry A de C Foley said:
This post is no use without pictures.Please.
tac
www.ovgrs.org
I see a Forney in my future. Just started looking at prices in GR.
Doug Arnold said:I just got one when I was at York. I great engine and half the price of the Bachmann Forney. All it needed was a paint job and some added details. Between that and my HLW big john the KMRR has two reliable engines.
I have an LGB Forney converted to to battery power using the Revolution TE with 16 2500Mah NiMH cells in a trailing combine. I regularly get over 4 hours on a charge.
