Hi all,
I finished a section of the new RR and fired up the Connie; Airwire, Phoenix, Battery, and set off up the hill.
Right away as I increased speed the sound started lowering and finally stopped as I increased the throttle more.
I noticed that even at full throttle the speed was not what it should be, cranked to 28 and barely moving along up the
2 % with 2 cars and caboose.
As I decreased the speed to almost a stop the sound started picking back up to set volume. Same thing going back down the hill but to a lesser degree
Well, I thought, been a while since I charged the battery must be low. I ran back into shop and put it on the charger. It charged for 18 minutes to 224 mah and shut off. Hummm that’s odd, I re-set the charger and it went for 42 minutes and 460 mah and shut off. That didn’t seem right for a 3300mah battery.
I fired up the engine and ran it just back and forth in the shop (it has started raining again) and it seemed fine with that light load.
Started wondering if the battery was failing, can’t be that old, just built that loco 4-5 years ago. So I looked up the paperwork, hmmmm Jan 2007 it Was put in service, little longer ago than I thought, and of course it sat idle (with just an occasional charge) for over 2 years while we moved and rebuilt.
So all this long winded story is leading up to is a couple of questions.
1- How long do these batteries last ( these are NimH) ?
2- Should I consider LI if I replace?
Thanks for any insight.
Rick
