John Bouck said:John you are not correct re the P5. I have them here and the P5T. I have been working with Phoenix to make them plug in compatible with RCS. They are not designed for use with regular track powered locos.
<> Dave, The P-5 has no input for "idling, standing sounds". Just the track (battery) power input. it relies on you sectioning off a piece of your battery pack, like I 'splained above. That's why it's cheaper. There are no inputs for reed switches, idling battery, etc. There isn't a speaker supplied with it either. Just a programming plug and an volume switch. It is supplied with inputs that hook to your receiver to ring the bell, blow the horn, instead of using the old track magnet reed switches.
The P5 does indeed have standing idling sounds when connected to the traction batteries.
You do not need to “secton off” part of your battery voltage to power it.
You simply connect the two green wires to the battery voltage. Up to 30 volts.
When you turn it on it idles.
There are two trigger inputs provided.
One is used for determining the speed of the diesel engine or chuff using a reed switch and magnet.
The other trigger can be used for a Whistle/Horn.
The Bell can be set up to work automatically.
When you plug in the P5T you can then use the Orange and Grey wires to reference the motor ouput to determine engine speed.
You wll also have 6 triggers for sound functions. With the soon to be released 6904 program you can trigger either high or low.
You haven’t said which brand of R/C you will be using and it does depend to some extent on how you will wire up the sound. If you will be triggering the sound with R/C then the P5 is ideal. If no R/C triggers then the P5 is not suitable and the P2K2 will be better. Be prepared for reduced range with the P2K2.
BTW. If you have high voltage and only run at half speed, the extra battery voltage not being used is burned off in the form of heat. It is much better to have just a volt or two above that required for the maximum speed you want to run at.
