Tim.
The short answer is yes.
However, if the loco also has a DCC decoder fitted, you must remove it or it may get “confused” if you are using a pwm controller.
There are two ways you can convert to battery R/C.
- Simply remove the track pick ups and feed the output of the R/C controller to the existing LGB wiring.
This enables all start up sounds and correct directional toots.
The trade off is you will need much higher battery voltage to operate the loco.
- Isolate the motor(s) from the LGB electronics and power them direct from the motor driver output and power the sound direct from the batteries.
You will require much less battery voltage, but the trade off is you lose start up and directional sound.
R/C operation for the whistle and bell requires tapping into the magnetic triggers in the motor block.
