David Maynard said:
Cliff Jennings said:
Echoing what David M said, HF air hose might be a lot cheaper than copper. For example, $50 for a “premium” 1/2" 100’ coil. Copper, at 1/2" nom, 10x 10’ long would be at least twice that (in type “L”).
I don’t know though what the codes might say about “permanently” installing hose for this sort of service.
Cliff, I don’t worry about codes, because my installs aren’t permanent. In a home shop setting, I am not sure codes would apply unless the install is suggested to be permanent. My hose through the attic system only lasted about 10 years or so. My new work area has extension cords running under the floor. The floor, the walls, the power, all of it is of a temporary nature. If/when it comes time to sell the house, all of that will be removed before the first appraisal.
Building codes have no bearing on our home shop “cobble ins” whether its electrical, plumbing, or even carpentry until there is a problem or accident and your home owners insurance investigator arrives. Then all of a sudden building code violations figure very prominently in the situation.
I have always felt that if I’m doing it myself it is best to do it to code.
A retired Mechanical Contractor myself I agree completely with Michael Glavin’s post above. One further thing I would recommend and have done is use 3/4 inch pipe for any runs over 25-30 feet and then reduce, it’s that old problem of volume (cfm storage)
Rick
this runs this
the purple spray gun.
