Building was made using part of a Wells Fargo Pola build that had been damaged in a storm. The building actually supplied enough material to build this and 2 others. This is one of my first buildings that kit bashed, and at that time I had just gotten into LED’s so this one is Battery powered. It has lights inside the building, 1 under the canopy where the pumps are and 1 each in the Texaco stars on the top of the building, and switch for same is just under the eve of the rear of the building which you can see just above the Texaco sign on rear of building. I changed the hoses on the pumps to a finer more realistic tubing. Funny thing that you can’t see in the pictures but the 1920ish pumps have a EPA lead warranting. The roof I weathered like an old station that I remember that the owner had replace 1 rusted out roof panel( I get a lot of ? about why I didn’t paint that panel, too funny., Side doors do open and station now has an old time coke cooler out in front, air compressor out back
and added old time decals.
