Here’s the latest on the depot…slow and unsteady. hehe! Part One… http://www.largescalecentral.com/LSCForums/viewtopic.php?id=8667
Window frames on, ready for siding.
Unfurnished interior view looking towards front.
Interior looking towards bay window. “Wood” floor is scribed pvc coated with spray stain and allowed to dry. Counter also is same but with a darker stain.
Exterior cedar siding boards are cut and individually fitted then removed in order and painted on both sides.
Glue is applied in beads on structure one section at a time. Welder illustrated is available at Walmart and other stores. There is also a larger 4oz size in a silver tube, same stuff but no longer available at our local Walmart.
Glue is spread out with a small stick to cover as completely as possible.
The precut and painted boards are laid into the glue in order.
Here’s the depot with the siding on.
The roof is clear acrylic, very handy for placing the intrior bracing as you can see through it. I also have used pvc with great success for roofs.
The clear roof set in place gives an idea of what it’ll look like.
The upper floor was painted black as there’ll be no interior detail upstairs. Lights for downstairs are merely poked through holes and the wires from the exterior lights are run up and through slots cut around the periphery to allow floor to be removed for access.
18 ga. bare copper wire is used as bus bars to which bulb leads are soldered. 12 volt electric service will be fed up through a hole in the floor in the baggage section.
Lights temporarily hooked up with test leads.
A not so good photo gives some idea of what the lower floor will look like. Roof detail and painting are next.
