I got a bunch of Aristo hopper on a Trainword blowout just after I pulled up the last layout. Thought it was time to do something with them. I was going to do a coal rake, but since I don’t have any coal on hand a ballast train was a good substitute.
First step was to lose the Aristo couplers, and close up the gap between the cars. I used a K&S brass strip mounted with the coupler mounting screws to make a fixed train of 8 cars.
The uselessness of which became apparent as soon as I went to move them to the layout.
I guess it’ll be fine once I have track storage on the layout but not so good at the moment.
So I split each drawbar in two and jury rigged a pin using a rivet and some C channel to lock the joint.
I sieved some crusher dust to get the stone. A 1mm kitchen sieve, 2mm colander and some 3mm ( 6 mesh) gave a good range. The stone between 2 & 3 mm equates to 40/60 mm which is right on target for ballast. I think that’s about 1 ½ - 2 ½ inch range. Ish.
I made the loads up using dilute white glue, same as indoor ballast. Used a template, polyurethaned, added baking paper then sprayed the lot with cooking oil to be sure nothing stuck. Still didn’t work that well.
But I guess it was better than doing nothing…
Pretty happy with how the first test load looked.
More to come.
Cheers
N
