I have no way of uploading photos right now as I’m back east for a bit, but I experimented with working brakes on a caboose on my dad’s railroad. I did this for the same reasons John mentions–surging on steep downgrades. Dad’s got a killer 5% on his line and many locos surge going down.
It’s an experiment that still needs some tweaking, but essentially it works by tightening a string wrapped around the axle. The tricky thing is that there’s a very fine line between drag and locked wheels. That, and the direction the string is wrapped around the axles affects how well it slows them, so there’s a difference in efficacy based on direction of travel.
What I’ve found so far with what experiments I’ve been able to do is that I can introduce enough drag with this mechanism to allow me to retard about 3 cars on the train. If our average down-grade train is 6 cars, that leaves 3 pushing against the locomotive. That seems to be under the threshold for the surging for all but our most egregious offenders, but it’s far from perfect. I’d like to get something that will allow us retard the entire train, so the couplers are all in tension on the way down the hill. I can probably get around the directional problem by fitting the brakes independently to both trucks, so you’d only apply the one set depending on which way you’re traveling. I didn’t have a chance to look into that this trip, as I spent my time working with three of dad’s newer locos, and fixing any operational or clearance issues they had. None of them exhibited any surging on the steep grade–even with as many as 10 cars in tow–so there was no incentive to revisit the issue.
I’ll take some pics and post them when I get back home.
