Here’s a wrecker I built. Copied from an old SOO line wrecker from the late 1800’s. I found the drawings in my drawing binder.
Made from a 27’ boxcar, the backshop went to work and built the wrecker. As per the prototype, the wrecker did not have any winches on board, but relied on an auxiliary means of raising and lowering the hook. Sometimes even a switch engine would pull the cable thru the car. The would use cribbing and any other means of securing the car so it wouldn’t take a nose dive. The boom does not swing. It is used to re-rail that have derailed, or to lift cars to put new trucks under them.
