Mark Demyan said:
Pete Thornton said:
Mark,
If you have an old 2-4-2, not the latest version, then I can help. I’m pretty sure the wheels on the plastic gear (original) version are just a press fit into the hubs containing the gears. All that stopped them falling out was the dummy outside frames and the thick flanges inside the rails!
Try pulling them out, or leveraging (carefully) with a screwdriver once the plastic outside frames and the rods are off.
Thanks Pete. After realizing that I had to take drastic measures if I was to move forward I used the Dremel to make a slot in the head to try rotating it with a screwdriver only to find out it is made of plastic and is pressed in as you described. Unfortunately it destroyed that pin but I was able to remove the other pins and move forward. Now I have to create a replacement pin unless these are available to buy somewhere.
I assume you are referring to the pins holding the rods to the wheels? Yes - they are just a press fit in the wheel. I doubt you can buy one, but it would be very simple to make a replacement or find an alternative. A nail or screw with the right size head could be filed down to fit and then glued in place. If you can ease the remains of the pin out, you could make something to fit it that looked like the old pin. It’s nylon, I believe, and difficult to glue, but a tiny bolt could be run into it to hold a new ‘head’ on the shank.
I’d suggest calling Bachmann’s repair shop in Philly. They often have junker locos lying around and may be able to find you some pins.
