David Kapp said:
Do you think that the Chinese are as good as a cat to come when called?
David: Basic intelligence tests comparing Americans (mostly whites of European ancestry) to a variety of Asian and other peoples, have found that North America peoples are of superior intellect. The problem is that these tests have mostly been devised and administered by folks of white European ancestry. When the ability and willingness to perform repetitive complex tasks with good precision is tested, Asian peoples are the clear winners (over both cats and other human strains). Still, the Chinese workers are not our slaves, and therefore aren’t required “. . . to come when called.”
David Kapp said:
I mean they are not noted for quality workmanship.
The reason “they” are not “noted for quality workmanship” is that the (again mostly North American) folks who employ “them” to produce that perfect product nearly universally put dollars first. The fact that we expect 100% perfect quality at the absolute “lowest price, always the lowest price” drives the amount of money the supplier can / will spend to produce a perfect product.
David Kapp said:
I don’t know why people put up wit (sic) it.
No one forced you to purchase the locomotive. I know several U.S. model makers who will build you a ‘perfect’ Shay. Starting costs are in the $5,000 range, and there is still no guarantee that the resulting model will not suffer from a bad solder joint.
David Kapp said:
I’m quite sick of the crap they send here.
Then don’t purchase it, or purchase one from another supplier. Why would you purchase a hobby item that is supposed to give you pleasure, then hate it? I’m certain the supplier has a return policy. Send the “crap” back. That will show “them” that we won’t put up with it.
David Kapp said:
I’m going to go over there and punch their leader right in the suck-hole. (mouth)
Okay, if that will make you feel better. Personally, I avoid making threats on the internet, no matter how much they might be deserved.
Tom Grabenstein said:
Yes, I had the exact same problem with my new three truck Shay. My front truck was missing a solder point on the circular ring and the wire was just sitting there intermittently sending the juice to the electric motor in the front truck. This problem was noted after a battery install and RC conversion by Don Sweet and RCS of New England. It was quite embarassing with my RR buddies over to see the “new Shay” and two out of three trucks had power and quite suddenly the first truck quit. The big loco went nowhere. I sent the engine back to Don instead of Bachmann as I was uncertain if my warranty was voided with the conversion. Don found were the factory forgot to solder a wire and repaired it quickly at no charge. He also walked me through the emotional let down of my first Large Scale locomotive failing immediately after purchase. He too reported this was “par for the course” and frequent rewiring jobs and tweaking were needed on many of the Bachmann Shays. He was quite a lot of help. Here is the Shay months later running like a champ on my Little River Railroad layout. I learned a lot about Large Scale Rail Roading with this electrical glitch and the good folks like Don Sweet out there who can help with problem solving.
(http://i542.photobucket.com/albums/gg412/DrGrab/trestleandShay.jpg)
Doc Tom
Tom: First, thanks for the recent pix of your layout. Looks great. As to your problem with the Shay, I hope we all realize that the loose connection could have been the result of a manufacturing defect, or shipping damage when it went from the factory to you to Don Sweet then back to you. The fact that Don converted the locomotive and obviously tested it without finding the defect pretty much shows that the problem probably occurred during shipment from Don to you, or during the unpacking and setup. Although a possible cause, it’s not obvious that it is directly associated with the manufacturing. Still, I hate it when something I bought in good faith doesn’t work to my expectations! Happy RRing, Jerry
