Guys, I acquired a B’mann Spectrum Mogul which had been dropped and damaged, plus someone had extensively re-wired it for battery and sound operation. (All I got was a Phoenix speaker in the tender, and a lot of connectors between the engine and tender!)
It had the usual cracked gear, so while replacing that (with a 25 tooth 2-8-0 gear again, not the 24 that NWSL suggests,) the motor came out. Underneath I found lots of wires which don’t appear to do anything.
As you can see, the connector with the 4 black wires isn’t connected to anything, nor are the red/yellow/brown/orange loose wires.
Interestingly, it seems to work, and the NMRA switch behind the (glued up) smoke box door is connected. Even the firebox glow is working. The chuff trigger is missing.
Can anyone tell me what the chuff trigger looks like? Maybe sell me one - though I can probably make one easily.
What are all those wires for? Anyone know?
