I first took the gear and meshed it with its mated gear and I think it is a great fit. So I went to put it on the axle. I wouldn’t go on even with light tapping. I rolled a piece of sand paper and honed it out til I could tap it on. Still a bit to tight in my opinion. But I am leaving it. If it splits I will sand the next one a little more. But the design works great. I put the shoulder to the outside and even though all the shoulder is on one side it has plenty of clearance and is not an issue. Should I need to I can add the brass tubing with ease.
I will need to get the loco running to make a final appraisal but I think this is going to work. Just as Dick is having success I believe I will also. We might have a real solution to the cracked gear syndrome. Making the gear in TinkerCAD was easy and it exports in a file readily readable by the 3D printer. so this really should be an easy and inexpensive solution.
Once I determine that the gear works well I will have Peter print me a few extras and then send John C some that are oversized and have him cast them in brass. IF those work then we really will have a great solution for one off gear replacement that wont break the bank and require someone to buy 10,000 of them
Both are gears Peter printed. one installed one as I received it. Very clean print. Nothing to trim or clean
