I’ve converted a number of engines to R/C battery already. I finally decided to convert my “older model” K27 to R/C battery control. I’m using a RailBoss system and Phoenix P8 sound. I’ve been successful so far with the controller and sound card installations and everything works to this point. I had removed the “dummy” card first. I have yet to decide whether to use the optical sensor or reed switch for chuff, but that’s another story for later.
My main question is related to lighting. When I converted my Bachmann C19 to R/C battery, all the lighting worked with no further modifications. However, none of the lights work in my K27 following the conversion. What am I missing? I just assumed the main PCB in the K27 tender performed the same basic functions as the one in the C19 tender. In-other-words, once power is supplied from the battery to the main board, the lighting would work. It doesn’t seem to be the case.
Any suggestions? I’d hate to think that I’m going to have to power the lights from the RailBoss card but, if necessary I will.
If I can get a solution to this issue, I will follow with a question regarding using the optical sensors for chuff.
Doc Watson
