Bachmann K-27 LED replacement
I know its been asked but I cant seem to find out where…
What is the easiest way to get into the headlight housing to change out the orange LED?
Most Bachmann lights sit on two supports that are held to a platform with tabs. Push the supports toward the center and you should be able to lift the light.
On the bottom of the casing is a hole. Put a brass rod a small wooden dowel through the hole to push the reflector and lens out. Then you can remove the LED.
Most Bachmann LEDs are wired black wire positive, red wire negative.
Thanks Paul, That’s what I needed.
