Bachmann James conversion
When the Thomas series “James” locomotive was released a couple of years ago, I picked up a few of them as I intended a conversion based on a 2-6-0 export plantation locomotive.
After a year or so of abscence from kitbashing I decided this weekend to start the conversion. First off was adding outside cylinders. I believe that they came from an old Aristo Porter (?) 2-4-2 locomotive. The drive rod did not require modifying and the piston stroke was perfect for the Bachmann wheel.
Alas, I struck a major hurdle. It seems the connecting rod mount screws are superglued into the wheel casting. The first one came out with a lot of trepidation, however, the second one sheared the head off. I have never seen these screws glued on the Anniversary locomotive (same screw), but for some ridiculously obscure reason the screws were glued. Fortunately I was able to drill out the broken screw and encourage a new thread to mount the drive rod.
As luck would have it, Lionel largescale drive rod screws (remember the old 0-6-0 locomotive)are the same thread pitch and screwed straight into the Bachmann wheel. Encouraged by this stroke of luck I continued modifying the locomotive.
The stock James ‘brass’ steam dome is far too anaemic. so I modified a Bachmann Annie sand dome to fit. The inside diameter of the sand dome is a neat fit over the stock James dome, however, the stock dome requires about 0.25" removed to allow the sand dome to fit flush to the boiler.
Further encouraged I made a new pilot truck that extends the pilot axle 1 cm forward. This gives a more prototypical appearance in relation to the added cylinders.
One day when I feel further enthused I will make a new smokebox door and add some cab backhead details and give the whole lot a lick of black paint.
Pictures please!
Yes, please!
Alas, the new site format is not too ‘friendly’ as to picture hosting so no photographs, sorry.
Tim,
Out of pure curiosity, where do you store your photographs? This is the easiest site I have ever been on to post pics to.
Bob C.
Bob,
I do not host photographs on any web site. My photographs are on my computer. Some forum sites will host uploaded photographs from your computer, but since the change in forum format, I believe a Freight Shed bandwidth would need to be purchased to store photographs on this site, if not hosted elsewhere.
That is not the case. You can store up to 10 MB of pictures for free.
Joe,
I went to my Freight Shed but could not see any link to upload an image to the site to enable posting. The old site was dead easy to post an image.
I managed to upload an image to my Freight Shed, but when I open the Freight shed to slect an image for a post response, the image, while showing in the Freight shed, does not show up in the Freight shed popup box when posting a reply.
I selected the image to upload into the forum files folio and it does appear in the folio when the Freight shed is selected open, but not when opening the Freight Shed to include an image in a post response.
