I recently bought a pair of replacement wheels for the large scale handcar, which I intend to use on a scratchbuilt railcar. The wheels arrived yesterday. Each wheel has half an axle, and there is a short length of gray plastic tube. I assume this is supposed to be used to join the axle together, preventing a short circuit through the axle. Problem is, there’s no way the axle stubs will fit into the tube. Do I just need to find another tube with a larger inside diameter, or is there something else I’m supposed to do with this?
Also, the wheels came with a thin plastic washer that fits over an axle. What is the purpose of this washer?
