Bachmann Goose #1 surging, any fix?
I’m going to be working on my Bachmann Goose #1 this summer. Is there any fix for the downgrade surging?
By Goose, do you mean the Railtruck? If so, check out George Schreyer’s site:
Bachmann Railtruck tips
George Schreyer address this problem on his web page.
http://girr.org/girr/tips/tips8/bachmann_railtruck_tips.html
*Mark posted while I was typing
All of the above… + the “procedure” as he was encouraged to call it was developed by TOC:
http://www.largescalecentral.com/forums/topic/5870/bachmann-1-20-railtruck-procedur
I did the fix on mine and it helped a bunch, but still had minimal surge
Thanks for these links.
I was aware of the screw change out to protect from excessive gear wear. But I was wondering if anyone has come up with a way to eliminate the grade surging. From the links posted it doesn’t look like a fix has been developed yet.
So she’ll surge. I’ll say the driver has trouble shifting gears.
Matt,
Geo. Schreyer says it does work. Didn’t you watch his clip?
http://girr.org/girr/tips/tips8/bmann_railtruck_surging_fixed.mov
Joe Zullo said:
Matt,
The clip wouldn’t open for me. I think my adblocker and cookie blocker might be preventing the quicktime video from opening.
I’m also a bit hesitant to add drag to the Goose since I run it on a small battery. But if this is the easiest fix I’ll give it a try.
Update, got the clip to work. Was my adblocker (http://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-embarassed.gif)
How steep is your grade? Mine is near 5% in spots and everything I own from Bachmann surges on the steep parts. I figure it can’t be helped. Technically is has to do with the gear design & tolerances. Not something I have the expertise to correct.
About 2% to 2.5% at the steepest.
Well that shouldn’t be a big problem then.
Matt,
Geo. Schreyer stated that his grade was 4% and the drag he added fixed his surge.
I did the drag fix for someone’s railtruck and while it did work it cut it’s battery life almost in half.
T
I believe George Schreyer runs track power, so it wasn’t an issue for him.
He runs DCC… even better than just track power. (http://www.largescalecentral.com/externals/tinymce/plugins/emoticons/img/smiley-tongue-out.gif)
Maybe is Revulsion and better than dcc?
Drag is a bad thing with on-board power. I did all sorts of stuff…tried a new driveshaft with tubing instead of their loosie-goosie u-joints. Not worth the effort.
TOC
