I just got a deal on a Bachmann Forney. My plan is to make it battery powered using the RCS TX1. I would like to make this as simple as possible. It has the Plug and Play, something that I have no clue about, other then you can simply add RC to it. I know their has been debates about the plug and play socket. I do not want this to turn into a pissing match. let me repeat I DO NOT WANT THIS TO TURN INTO A PISSING MATCH…
OK so I have an RCS Rx65b electronic speed controller. My question is: will this plug right into the forney? if not how hard is it to get it to work or would I be better off getting something that does fit? I want to keep this simple and utilize whats available. Im not adding any extra sounds etc… Just want to use whats already in the Forney. I have no problem getting a speed controller that fits into the plug and play socket if thats the best solution. But if I can wire the Rx65b easily to make it compatible ill do that. Thanks for putting up with my non electronic skills lol…
I also sent Tony an Email concerning the Rx565b
