With the shop cleaned up from the Mik Challenge I decided it was time to get some unfinished projects done. M-11 has been out-of-service for over a year due to coupler problems. I use Accucraft F scale couplers and have tried various methos of attaching them to my 45 Ton diesels. None of my methods to date have worked well. I tried modifying an Accucraft coupler to fit into the provided coupler mount, but the height was too far off in either the high or low position. Next I settled on just using a screw to hold a modified Kadee draft box to the pilot. This worked well for height, but the screw kept coming loose sometimes with catastrophic results
I think it was one of those incidents that moved M-11 to the dead line.
Looking at how others have done it I see that Accucrafts bulkhead draft gear is used. I bought a bunch of Accucraft AP-11730’s last year at ECLSTS but never got around to mounting them…
It seems I was over thinking it. I was sure I was going to need to create a mounting plate to cover the stock opening on the pilot. In looking at it again yesterday I discovered that the existing slots lined up perfectly with the mounting holes in the draft gear. I just needed some longer screws and a backing plate. Digging through my stock I found some M2x12mm hex cap screws and nuts and some 1/2" brass strip. I cut the strip about 1/4" wider than the draft gear then drilled it to accept the M2 screws using the draft gear to mark it out.
I assembled the screws, plate and nuts then slid it up the pilot slot from the bottom. Once I was certain the coupler was fully seated at the top of the slot I tightened down the screws. This is what it looks like from the back…
Since this area really isn’t visible when the loco is running I didn’t worry about making it pretty. A #4x.75" sheet metal screw was driven up through the bottom into the pilot to help keep it at the top of the slots. Note that the draft gear needs to be drilled out a bit to accept a #4 screw…
A little further away for context…
And from the front…
While I was at it I made the stock lift bar functional. I used some small jewellery chain and eye pins found at Michael’s…
The eye pin was bent using needle nose pliers to make an attachment for the lift bar…
Coupler closed - at rest…
And open with the bar lifted…
I still need to weather the chain and eye pin. And I’m not in love with the hex cap screws, but i had them in stock and M-11 is finally back in service.
