Update:
Gears are on hand. Let the adventure begin!
Update:
Update:
Today was the day. A passing hurricane made diving an iffy proposition, so the 1:1 crew being busy, the1:24 gang and I set-to to bring North Star back to life.
First things first, though. Many thanks to Pete ( @PeterT ) for his posts above, or I would never have figured out how to get those wheels off! Secondly, kudos to him for identifying the issue. You can see the black line above that is actually the split in the collar.
Removing the drive rods and prying the wheel covers off with a flathead screwdriver proved relatively easy.
After removing one wheel, I studied the chassis a bit to see how best to tap out the axle. It turned out I first had to remove a pin above the driver. I used a small screwdriver and tack hammer to lightly tap it out…
…which let me pivot out the motor block.
Next, I fiddled around with the motor block and my vice…
I would like to point out a good design feature here. I was worried about quartering. The axle ends are, for lack of a better description, “Zepplin-shaped,” so the wheels go on quartered. There. I said it. Bachmann did do something right.
Moving right along, Kid-zilla did join me at this point, roughly 2 hours into the process, for reassembly, testing, and fitting out. Here, he replaces the weight.
Kid-zilla had taken the tablet at some point, as he thought everyone should see the new gear in place…
At last we loaded the 1:24 gang into their work caboose, hooked in a car, and placed North Star on the track.
Video evidence tomorrow, if I can manage that, but otherwise this project is pau (finished)! Thanks again for all the help along the way!
Addendum:
As promised, here is proof we fixed North Star, our Bachmann 10-Wheller (filmography courtesy of Kid-zilla):
Have a great week everyone!
Well done …It seams Kid-Zilla is finding some calmness as he’s discovering life…
I periodically stop and whine too, but there is no fix.
Great job in North Star!
Yep. I am hoping he doesn’t take the skills and interests and apply them to his own hobbies like his older siblings did!
