Hi all. Though I’d keep a log of this project here for the amusement of those who wont go there. This was part of another topic on another forum, about converting the 10 wheeler to an 8 wheeler, but it will be easier for me to keep track of my progress with a dedicated log to convert a Bachmann Bug Mauler to a 4-4-0 late American locomotive. This is an earler version of the Bug Mauler so if I screw the pooch on it I wont loose much[:I] This might be easier than I though… Against my better judgement last night I took razorsaw, drill and Xacto blade to my Bug Mauler and within an hour I had relocated the front axle. I removed the brake arms and found that the mounting notch was right about where I wanted to relocate the axle to. So I used the notches for the brake arms as the mounting point, keeping one side of notch untouched, that way I had one fixed dimension to keep the axle aligned straight, its about a 1-1/2" move. Then I carefully cut a drill hole (1/8" I think) to create the fixed bearing depth. I then used the Xacto and razor saw to work the bearing up from that point to match the bearing shape of the other axles. I had to cut out the chuff synchronizer to relocate the axle but I dont use sound so thats fine with me. The big trouble I am having now is trying to rework the existing power pick up backwords to the new location. So far its not working out as I would hope and I’m beginning to believe I’ll have to replace them with new pickups. It works it just not pretty. I created a templete for the drive rods so I can cut down the existing plus the pushrod has to be cut down. I’ve done that already on another chassis so that wasnt to tough. I need to add a shim and use a metal screw in lieu of the plastic push pins the Bug Mauler used to secure the drive rods. Ok pics… Conversion
Chassis cut for axles, 1-1/2" move
Another view of axle cut
Connecting rod shortened and templete, new dimension in 3-25/32"
Connecting rod in place
Its a motely mix of whatever Bug Mauler parts I have left laying around. More as I progress[:D]
