E. Paul Austin said:
An RCS board which is used to power the Serria Sound board and control the power up and advance of the throttle. The sound board then uses battary power and not the 'little' battary that you can get with it.
Does that help?
Paul
I think so. But with the demise of Sierra I guess the question is no longer moot.
Anyhow, it’s like this, Sir. I have a bunch of Aristo-Craft Dash 9s, SD45s and FA’s [fifteen], into which I am putting the new QSI sound system that operates via track power. I also have the neat little hand-held controller that allows you to control all the sounds that you would get if you were running it with DCC. Some folks laff at this little board and it’s cute sounds, but I like it and the things it allows me to do without the cost and pain of either DCC or radio systems, although I DO run my steamies with radio.
I was rather hoping that there was a similar QSI sound card that would fit the three-truck Shay and allow me to use this hand-held sound controller, and not have to buy yet another system. Needless to say, I also have all the other Bachmann geared loco, as well as the Connie. My one-off Accucraft K-27 came with Sierra sound anyhow.
With around forty sparkie locos, I’m not yet ready to go to battery power, nor do I have the cash to do it. I’m not into multiple train running - my layout is small and only double-tracked, and optimised for Gauge 1 live-steam passenger train whizz-around-type running, so when i run electrics it’s usually only one or two at a time, single or double-headed.
I do appreciate all the help and advice I get here, truly, and I’m trying very hard not to sound like a jerk or to be a PITA.
tac
