I have a 3 truck shay that has one wheel freezing on the centre truck which I fear is caused by the good old split gear. Looking around for a replacement I cannot find one to replace the gear (tried NWSL but couldn’t see one) but I did find this Motor Assembly (G Shay) (New) [M10051-0ZN02-0ZN01] - $62.32 : Bachmann Trains Online Store! does anybody know if this is a direct drop in replacement that I can use to repair/upgrade my truck. I have an old 38 Ton 2 truck shay as well so reckon that I will probably need some of these in the future.
If anybody knows where I can get a replacement gear I will be truly grateful for the knowledge.
Hello GAP,
The axle gears usually fail on the Shay, not the drive assembly you have posted from the website. The upside is pulling the axles is much easier than the full tear down of the power truck. The downside is if one gear is bad, the rest are not far behind. Once the gears became unavailable, I designed and printed a replacement. Let me check to see if I have any ready to go. How many would you need?
Don
Don,
I have 2 3D printers if you could share the stl’s that would be great.
What filament do you use/
If you are not prepared to share the stl’s, I will need enough to replace all the gears on a 3 truck and a 2 truck please.
I can send the file, no problem. Please contact me via private message and we can go from there. I printed my gears in PLA. I think they are holding up fine. If you decide to use another filament let me know.
DG
