Does someone could tell me the dimensions of 24.5mm Bachmann wheel set (item # 92422)? Thanks for your help!
OK, this will be based on a sample of one and there may be variations due to manufacturing tolerances. First off the diameter is measured across the wheel tread not the flanges and varies a bit due to the wheel taper but is close to 24.5 near the outside of the wheel. The dimension at the outside of the flange is 29.2mm. Axle to Axle length is 69.6mm. Inner hub to inner hub is 57.8mm assuming the back to back measurement is 40.0mm. The axle diameter is 3mm.
Hope this helps.
Thanks Gary ! It’s very helpful.
