OK…gotta a Bachmann 2-6-0 (the old timer, not the Indy) and last year ran fine until the drive gear cracked. I replaced the drive axle on the center driver, and the thing won;t track wortha darn! I was simply having an issue at two perticular turnouts, everything else ran over those places without a problem except for the 2-6-0, the front drivers came off the rail everytime.
So I had a notion that limiting the side to side play of the front set of drivers might be an answer, as the flanges on the drivers seem to pick at every track irregularity. Welp in pulling the front set of drivers to put on some spacers, I discovered that one of the springs that is part of the equalization was missing causing one driver to flop up and down. So silly me, I replaced the spring that was present and the missing one with KD coupler springs that seemed might be identical. Now the bloody thing won’t stay on the track at all on a curve. The drivers ride up and over the railhead and off she goes.
I’m really stuck for a fix at this point. anyone got any ideas short of hitting it several times with a large heavy hammer?
