Lock-Tite time!
We were alerted to a problem with screws on the new cars when we found a small machine screw in the bottom of the Styrofoam packaging on one of our review samples.
Inspection showed this to be a “sideframe” screw.
Technically, it is one of two that holds the upper spring perch to the truck bolster, but these also allow removal of the sideframe.
Inspection showed some of the review samples had VERY loose sideframe screws.
We removed the trucks, Lock-Tited with 222 LockTite ALL sideframe screws, and while doing this, discovered “some” of the review sample kingpin screws (which retain the trucks to the frame) were loose, some over 1/2 way out!
We Lock-Tited these also.
Heads-up, get them fixed before they disappear in the ballast on your railroad!
Approved by Bachmann.
TOC
ô ô
