I started out trying to model the Pittsburgh and Castle Shannon Railroad. Since the railroad was leased by, and eventually bought out by the Pittsburgh Railway Company, I also had to have some PRC streetcars. I have some Aristo PCCs, no none are painted PRC yet, and when I heard the Bachmann was coming out with a 1:29 streetcar, I added it to my wish list. At the last ECLSTS I purchased one. Its in Toronto colours, but its close to the colours the PRC used.
After I finished the
spring re-ballasting of my railroad, and redoing a section of track that needed upgraded, I took the streetcar out of the box. When I put it on the track and applied power, I found that it ran the wrong way. I know that Bachmann has a polarity switch on many of their products, to switch between Large scale and NMRA standard polarity. So I looked at the few instruction sheets that came with the car, and found out that the switches are under a cover on the underside of the middle of the car. The cover is held on with 4 very small screws. So I removed the cover and switched the polarity switch.
Once the thing was running the right way, I played with it for a while. The headlight is a yellowish colour, what I would expect on an old time streetcar. The rear makers are red, and bright enough to see in daylight.
I noticed, that at my normal track voltage for the Aristo PCCs, the Bachmann car ran noticeably faster. So I put them on the track together to see what the difference was. The Aristo car starts moving at about 4 volts on my panel mounted voltmeter. I do not know how accurate my meter is, but it gives me an idea of the voltage applied. The Bachmann car starts moving a bit below 8 volts. At around 11 volts the 2 ran at about the same speed. But my passengers have places to be, and lollygagging along at that speed just wont do. At about 16 volts, the cars move at a nice speed through my yard, but as I said before, the Bachmann car is a bit faster.
The Bachmann car has decent interior detail, at least what I could see through the windows.
But the step into the car is a but much.
For the few hours I ran the car, she ran smooth and quiet with no issues with the track switches. I don’t have any grade crossings nor cross overs, so I cant say how she would handle features like that.
The detail is pretty good. The roof vent screens are just printed on the roof vents. I may have to improve that detail if I ever get around to a proper re-lettering of her for the PRC. Overall I do like that car. I am not sure if I will purchase another one, since I don’t actually model the PRC.
