One of my two Bachman 45 ton locos has a surging problem that has gotten much worse lately. At first it was noticeable only on steep down-grade runs. It was bad enough to bang the couplers on a 4 car train. Lately it has gotten worse showing up even on level track. Yesterday one of the two trucks repeatedly stalled at slow speeds causing the wheels to skid.
I’m going to open up the truck and take a look for a foreign object in the gear grease, a loose motor mount or broken gear. Anything else I should be looking for?
BTW - This particular 45T has added weight over the problem truck. Most of the weight that came out of my Porter ended up being hot-glued into the rear hood looking for better traction. I wonder if I over did it.
My other 45T runs pretty smooth, even on the down grade with a train.
I’m really not wanting to tear down the whole loco again.
