I just got the Hartland flat cars and in the process of painting them. I want to convert the flats to the Bachmann knuckles (Kadee is out, bachmann is so much cheaper and they work for my purpose) I want to body mount them but the problem is since it is a flat car how do I get them screwed on without the screw punching through the top of the flat. Also should I take the knuckle off from the arm or leave it when installing them. What do I do with that plastic tail? The larger flats are different then the mini series. the hook and loop are attached to the trucks like the backmann flats. Thanks
