This is the second newest release 4-4-0 I’ve had in for axle gear issues. Eureka and Palisades.
Black gear (and lower tooth count…not a 2-8-0 count) instead of white.
I thought the first one was an aberration, but it ain’t.
They have done something with the molds for the drivers. You need 4 different tools and six hands to get the journal box off the wheel.
I checked with a dial caliper, the taper is astounding.
.005" to .006" from back of the wheel to the end.
Twisted some emery around the stub and worked it until the silly thing went in and out of the bushing in the journal box as it should.
Can’t be good for operation. In fact, the journal bushing was locked so hard on the right side, the bushing was turning in the plastic box.
I’ve done a LOT of gears on 2-8-0’s and the 4-4-0/2-6-0 series. NWSL never has gotten the instructions up to date, even though I’ve talked to them and sent drawings as requested.
You need about a .030" shim on each side of the gear. The Bach gear has a wide hub…the NWSL has no hub at all.
My nylon shims are .035", so, using the same emery paper, worked them down to .030", made sure there was “rattle” in the axle before putting valve gear and wheels on.
Who’s gonna be the first to label this as “bashing”?
