[b]A new industry for Bandon township…Foley Fast Freight Forwarders (4F Company)
An overview of the Bandon area showing progress thus far. The freight house can be seen in the distance as can the first fitting of the depot.
The dock built from PT 2x lumber with PVC expanded foam “cement” sections glued on top. The holes are for the dock roof supports. Color is Bondo primer grey.
Lower and upper walls. The lower wall section is already primed and textured while the upper section is as yet unpainted. Foley Freight is a “flat” and has only one main facade with short abreviated wall sections about 3" deep on either end.
Lower wall and dock section.
Lower wall fitted to dock section. The dock roof will sit on top of the lower wall edge and the upper wall section on top of that to secure the roof.
The upper wall here is being primed with Bondo grey primer.
Next the texture paint is applied. Color is chocolate although it looks more grey. The texture paint can be applied over the primer within minutes although the texture paint itself needs at least over night to dry.
Here is the area in which the warehouse will be installed. It will be screwed down onto the PT 2x4 which for this purpose is the “foundation”.
The main section installed outdoors. It is 61" long and has 3 freight doors. A small office section will be installed to the right of the main facade and be textured as the main section is.
There is an open area adjacent to the main freight house section that needs to be filled.
It was decided to use the area for a shop annex for Foley Fast Freight. It was set back for interest and to allow some space in front .
The shop annex all properly signed. The set back allows for a vehicle, or other detail, to be displayed without crowding.
Foley Fast Freight in an over all view. There is also an office annex at the other end not very visible unfortunately. It is a simple wall with three windows and textured to match the rest of the structure.
View from the depot end. There are three light fixtures, one over each door for night ops and photos. Much of the ballasting has been done around the freight house but further ballasting has to wait until the depot and adjacent area are properly planted in the soil. At least it’s operational for TAC’s (Terry Foley) visit. The honor of spotting the first car at Foley Fast Freight Forwarders will be reserved for him next week.[/b]
