Attention Bachman K-27 Owners
Is the front pilot truck on your k-27 broken? I had no idea mine was until I took a closer look after a friend alerted me to the problem earlier this year.
He sent me a potential solution to 3d print, designed by Dylan Huston.
The one issue I had with the design was the use of an active bistle post, which required a new hole to be machined in the deck plate. Dylan is a skilled machinist, but most folks would have trouble machining this hole. I also noted that the existing brass pin with the spring behind it was digging into the bottom of the pilot deck surface.
This new design solves several problems. It uses a 1/8 thick piece of brass as the base of the truck. It utilizes ball bearings to fit on the existing axle with a little polishing. The remainder is 3d printed parts in Formlabs Tough 2000 resin that I have found to be impervious to breakage. The bump stop on the top is designed to slide easer on the bottom of the deck plate. So it is very durable, and with the low slung brass frame tracks much better. I cannot guarantee you will be derailment free, but your new front truck is reasonably indestructible.
I currently have the first batch of these in service with several owners
For a limited time (depending on demand) I am offering a kit for this new pilot truck for $30.00 plus $10.00 priority mail shipping. I can fit up to three kits in a small flat rate box, if you need more than one.
At this time I am looking for reservations. I need to purchase the brass frames in min lots of 12 pieces to make this price work, and I am not making a lot of $$ here either, more so looking to keep these locomotives going for years to come.
Please send me a PM on this forum to make a reservation. Please include your shipping address and contact email, so when ready I can send you the info for a PayPal payment, or contact info if you wish to send a check.
Al P.
If you are a Bachmann K27 owner I highly recommend getting one of these. This is a large improvement over the original ones.
Stan
Initial uptake has been slow, however i am now working on shipping the first ten kits. I have parts for another two on hand, and some parts for 13 more, but that will be the end.
Al P.
Good evening, do you have any G scale K-27 pilot kits still available for purchase? If so, I would like to order one. Unfortunately, this forum will not allow me to send a PM, as I just joined this evening.
Since Bachmann no longer shows replacement front pilot trucks in stock, seems like this is the only option for now.
Do a general search for K-27 and you might find fixes and/or replacements :sunglasses:
Are these kits still available?
For a limited time. the last batch for which i have most parts is filling up fast.
Check your messages for more info.
Al P.
Hello,
Currently i have enough reservations to start the last batch of kits and have only a couple unclaimed at this time, so if you have been waiting, time is of the essence.
Al P.
At this time i am fully reserved. future offerings may be less hardware and Bearings, or if a manufacture is interested in adding to there line.
Thank you for your interest.
AL P.
Currently i am working on shipping this last batch. if you have not heard from me please check your spam folder.
If you missed out and still want to reserve, i will take your info, however the price cannot be held and will be advised at the time of my order placement for the brass frames the new cost. I absorbed a $1.00 increase per brass frame due to price increases.
AL P.
PM sent to you this morning.
Sent a PM this morning.
Are these K-27 pilot truck kits still available? Thanks.
LJ
good afternoon. I would like to buy one if any are still available. mine isn’t broken, but with almost zero weight in it the pilot is all but useless
thank you
.Chris
Chris, yours is the first request in over a year, and i do not have any of the commercial parts either.
i can see about a small order of the brass part. the atvanage of doing in big lots is the per piece price goes down.
Al P
yessir I understand that, mine tracks terribly, Im willing to pay a little more to have an expensive loco not be a disappointment
See you Private messages. your icon will have a notification dot.
Al.
I was recommended by Chris that you have upgraded pilots. I’d like to buy one from you please.
Al
PM sent.
vvvvvvvvvvvvvvvvvvvvvvvvvvvv < to get to Bob’s 20 character limit. :grin:
John i sent you a private message look in the upper right where your icon is.
AL P.
