Terry A de C Foley said:
Remember that LGB insists that ALL its locomotives should be able to negotiate R1 track, just in case your five-year-olds are going to run your $5000 loco around the settee and under the TV.
The plastic mike and the WP mike share the same mechanism as far as the basic design is concerned - one where the chassis hinges in the middle and the side rods are slotted to compensate for the movement.
I was not aware that Aster had done anything except make the very fine bodywork, at least, according to Aster.
The 22 pound-weight Aster model has a real problem hauling a long consist, but then, the real thing didn’t haul long trains anyhow.
I maintain that the main problem is one of keeping all the drive wheels on the track - mine only has half of them on the track at any one time due to the ‘flex’ in the chassis - see my initial post on the bendy chassis. …
tac
www.ovgrs.org
Terry, sorry to hear about your
#73. I gave this problem a careful consideration, and I think I have a solution. If you are not concerned with R1 rule, why not apply some superglue to the hinges in the middle - this will prevent the chassis from bending;-))), and the problem should be solved!! More seriously, I think that if the problem is as you described to Tamada-san at the Kichijoji meeting, ie. that the middle wheels go up, this essentially means that the motor blocks are not supported in the right place (middle of each block seems like the appropriate place for support). I have never unpacked my own
#73 hoping that I will find a fool greater than myself who will buy it from me still in the original box. This is why I do not know how the motor blocks are supported. If you could send me a photo that would help me think about it - I am not aware of any
#73 around here to be inspected (perhaps Aster warned local customers not to buy that piece of junk…). I also do not think Aster had anything to do with the drive. The drives were made by Aster in first four Limited Edition locomotives. I only have three of them and there is nothing wrong with them, in fact it would be difficult to find a better one than that on the K-28. 2-10-2 has problems due to the plastic wheels of poor quality, they are not Aster’s though. Starting from the NG13, LGB insisted on their own drives, apparently they felt they should blame Aster for the troubles with the Harz. But the all plastic drives on the NG13 are OK. The first total failure is the
#73. So why don’t you bring your dead one here, I am sure we will fix it with Tamada-san, best wishes from TOkyo, Zubi
