I’m converting an SD-45 over to onboard battery power with QSI decoder/sound board and G-Wire. Before I do the final installation… I was hooking everything up to make sure it works. I connected a Crest 21 volt battery to the cable next to the coupler to supply power. Everything seems to be working fine.
However… I noticed when the battery is connected as described above… and I move the Track/Battery slide switch from Battery to Track… I’m still getting Battery power. I thought this would disconnect all Battery power… so I could use it as an on-off switch.
I’m not going to use 2 rail power on the layout and plan on using just all battery power.
Is this wired wrong???
What is the purpose of this switch?
Thanks,
Russ
