The old Aristo-Craft motor blocks used on the vintage FA-1, RS-3, U25-B and others are easy to open and lubricate. These are the ones with the extended axles on the wheels that ride in brass/bronze bushings in the side frames. There are two screws at the end of the top motor block case half and four on the bottom. With the top half of the of the motor block case removed everything is accessible.
These old blocks are very durable and easy to maintain. They can be lumpy running because of wobbly wheels which can chew up the side frame bushings. I was able to buy some replacement bushings and chrome wheels from Navin when he worked for Aristo-Craft, but I don’t know whether they are still available. Most people just replace them with the new ball bearing motor blocks.
Although not a common problem with the older blocks, split axle shafts on the drive gear can be repaired with a metric tube brass collar using the same method to repair USA Trains drive gears. This repair can only be used with the fixed axles, as the collars will not fit in the pivoting gear boxes. However the axles can be disassembled and interchanged.
The newer ball bearing motor blocks are similar, but have fine un-insulated track power wires (AA and Z) between the motor block cases halves.
These wires can overheat during heavy and/or prolonged use. They can melt and stick to the case halves, then bend or break when the block is opened. I replaced a few by bending some fine brass rod to fit.
It appears in this image that the motor was mounted over one of the wires. However as both blocks were like this, I assume the wires heated and extended with severe use. The wires would then bend, touch the motor block case, cause a short circuit, and melt.
I also worked on two of four, new ball bearing blocks than ran lumpy. It turned out the shafts in the pivoting gear boxes were bent. As it would be impossible to bend a two inch chrome steel shaft in service without breaking the plastic gear box case, I assume they were bent at the factory when the worm gear was punched on. Fortunately these replacement motor blocks are used on the rear of a CPR FA-1 and FB-1 that are run as a set. So by removing the bent shafts from the gear cases of the rear motor blocks, this pair of diesels now run smoothly with three axles on each unit powered.
Over the years I have tried a number of greases to lubricate the drive gears in these motor blocks. Some flung off, others to turned to oil when agitated. The best I have found so far is the LGB gear lubricant grease. I have looked for the Mobil synthetic grease that several posters have recommended, but have yet to find it here in Canada.
