A brief update on the Aristo Dual Rail Bender:
What an awesome tool!
As I noted earlier, the main idea is to re-bend some 9 foot curves into some 20 foot and larger curves. I began laying track this week and it didn’t take long to reach the first curve. Being a rail bending virgin, I was a bit apprehensive about bending rail for the first time. I did some minor experimenting/practicing in the shop with a couple of 9 foot curves joined together with Hillman style clamps (they were actually not “Hillman” brand, but purchased from an eBay vendor). Other than a bit of shimming with some cardboard (to clear the tie plates), the tool worked great right out of the box. I use Aristo US ties, so the shim was necessary. Rumor has it that the Aristo Euro (narrow gauge) ties do not need the shim. In any case, the shim was easy to make and install (some thin cardboard from a small notepad did the trick). It does make me wonder why Aristo didn’t just use a slightly thicker plastic slide plate. No big deal. I thought about using Marty’s fix or even hitting the hardware store to look for bolts with smaller heads, but the shim fix only took a few seconds and I was off and running.
I only paid $70 for the tool when Aristo was going out of business. It was worth every penny! Easy to set up, easy to use, great results. What more could you ask for? Best $70 investment I made.
-Kevin.
