Hello, I don’t know if this subject has been brought up before or not but I know there are several folks out there who own one of the following locomotives and might be interested in installing a grease port to preserve the lifespan of the gears in these locomotives, especially if you run in hot environments and pull heavy trains.
These include,
Aristocraft,
Dash 9,
SD45
2-8-2
Mallet (2-8-8-2)
(There may be others with similar gearboxes also)
I have heard folks talk about the fear of gear failure in these Aristocraft locomotives due to the inability to grease the gears. The gearboxes are supposed to be sealed and never need grease.
We’ll I can tell you from repairing over 65 locomotives that this is as from the truth as you can get. Almost half of the locomotives gearboxes were completely dry on new locomotives I worked on.
So I decided to find a way to apply grease easily without disassembling the locomotive drive more than once.
I knew I had to drill grease ports but didn’t know how. So I began a long journey of educating myself on every part of these drives and now all our locomotives are able to be greased without disassembly.
I know this is a lot of information but I thought I would share the procedure with all of you so as to save as many drives as possible.
Especially since parts are scarce now that Aristocraft is partially gone.
This is the way I disassemble and drill grease ports on the above mentioned locomotives.
THIS JOB IS TEDIOUS AND TIME CONSUMING AND NEEDS TO BE DONE BY EXPERIENCED PEOPLE. THE INFORMATION PROVIDED IS SIMPLY AN AID AND A SUGGESTION. WE ARE IN NO WAY RESPONSIBLE FOR DAMAGES TO ANYONES EQUIPMENT DUE IMPROPER OR CARELESS DISASSEMBLY OR REASSEMBLY. THIS JOB SHOULD BE DONE BY AN EXPERIENCED TECHNICIAN.
THIS CAN ALSO VOID NEW EQUIPMENT WARRANTIES.
SO PERFORM THIS IMPROVEMENT AT YOUR OWN RISK!
- Remove all bottom plate screws (8)
- Using a flashlight, find and unsolder all clips that attach the motor leads to the power strips that are connected to the frame drive box.
(You will find them between the motor and gearboxes at the bottom)
They are rather hard to get to and in a tight spot so you will need a smaller soldering iron. - Make sure all leads are unsoldered and motors are completely loose. Then gently wiggle the gearboxes and motors as one big unit (all together) and remove them from the box.
- Make sure to keep everything in a line and replace it in the same spot it came out of. (In other words, don’t mix up the gearboxes or the motors) Make very sure to mark the top of each motor so that they don’t get reversed (turned upside down with opposing polarity) when removing gearboxes. This is easy to do and a motor turned upside down on reassembly can cause a short and you will have to disassemble the whole drive again.
- Slide one gearbox off the motor shaft at one end.
- Remove the two screws on the wheels and remove the wheels.
BE AWARE AND CAREFUL AS THE SCREWS USED BY ARISTOCRAFT ARE KNOWN TO BREAK OFF THE HEADS DUE TO AN ABUNDANCE OF GLUE USED TO HELP HOLD THE SCREWS IN TIGHTLY. THIS WAS DUE TO WHEELS SLIPPING ON TAPERED AXLES. NEVER USE EXCESSIVE PRESSURE. IF THE HEADS BREAK YOU WILL HAVE TO HAVE THEM DRILLED OUT OR REPLACE THE AXLE HALF.
THERE HAVE BEEN POSTS ON HOW TO DO THIS SAFELY AND YOU MAY WANT TO READ UP ON IT FIRST. - Remove the 4 long screws from the gearbox. (2 each side of gearbox)
DO NOT SLIDE GEARBOX APART YET! - These gearboxes have 1 small ball bearing electrical pickup and 1 spring in the plastic near the outside edge of the axle hole on both sides. ( 2 per gearbox)
SLOWLY AND GENTLY SLIDE THE GEARBOX APART ON ONE SIDE AT A TIME AND WATCH THAT YOU DO NOT LOOSE THE BALL BEARING AND SPRING WHEN PULLING THE AXLES OUT. LIKE KADEE SPRINGS, THEY CAN FLY A LONG WAY AND GET LOST EASY. REMOVE BALL BEARINGS AND SPRINGS. - Remove the axle/gear and worm gear keeping them in the same position for reassembly.
- Reassemble the gearbox with 2 long screws.
- Drill the size hole you feel you will need, space wise, to apply grease into the center bottom where the big main gear was.
- Remove the 2 screws, separate the gearbox and clean out any debris and smooth any edges.
- Replace the worm gear and put the springs back in.
- Use a small amount of conductive grease on the ball bearings and put them back on top of the springs.
- Slide the axle/gear back into the axle holes gently making sure the ball bearings and springs are compressed and stay put.
- After sliding both sections back together, replace the 4 long screws without over tightning.
- Slide the motor shaft back into the gearbox exactly as it was removed.
- Do all the other gearboxes in the same way.
- When all gearboxes are finished, replace the wheels (making sure to put the lightest loktight on the threads for future removal, if needed and don’t forget to quarter all wheels on steam engines) Then slide the motor/wheels/gearbox assembly back into the frame exactly as you removed it with all gearboxes in the same spots they came out of.
- MAKE SURE YOUR MOTORS ARE REPLACED AS MARKED FOR CORRECT POLARITY AND THE TRUCK ASSEMBLY IS THE CORRECT DIRECTION FOR CORRECT POLARITY ALSO.
MAKE SURE ALL MOTORS AND GEARBOXES ARE SEATED PROPERLY AT THE FRAME BOTTOM OR THE DRIVE WILL BIND OR RUN NOISILY. - Resolder the motor leads and bench test for binding.
SHOULD RUN SMOOTH AND IN THE CORRECT DIRECTION.
Make sure the floating gearboxes move freely side to side. - Mark and drill holes in the bottom plate above the existing gearbox holes and replace the cover and screws.
- Test run the drive by applying power to the power strips on top and once again, make sure that the floating gearboxes are free to move side to side and that there is no loud noise or binding. If the motor block starts getting too warm, it’s binding somewhere and you need to stop it and go back in and find out where it’s binding.
- Finally, grease the gears and put in a small rubber plug for the size hole you drilled in the bottom plate.
(Or use electrical tape like I did although it’s not the best idea especially if you run outdoors) - Put a drop of oil on the axles where they enter the gearbox so the ball bearing and spring are lubricated.
HOPE THIS HELPS YOUR LOCOMOTIVES RUN FOR MANY MORE YEARS.
Check out the photos as they may help and Happy Railroading!
