Wow, I am impressed!
I completely agree with what you are doing on the aristo locos, and they should last forever that way. (My guess your loco with the failed motors was due to misalignment between the motors and gearboxes at time of assembly/manufacture)
I know people that drill holes in the gearboxes (without disassembling) claiming that chips from drilling cannot get in the gearboxes, they are very careful. I’ve drilled a lot of holes in my time, some little bit at least gets into the hole. True, small chips of plastic might not do anything, or right away, but I would disassemble as you do.
Clearly you also understand that you don’t pack gearboxes with grease, it does nothing, you need it on the gears. That puts you in a pretty small group of people who actually understand gearboxes and grease.
also oiling the axles is a trick that few know, but it is a necessity:
on the SD70, I have never seen any diesel from USAT that never had the split axle problem. Typically, since the wheels still turn, and the other wheels pull the loco, many people are unaware they have this issue, until all the axles crack, and they finally notice the reduced pulling power.
It’s a simple inspection by trying to rotate the wheels on an axle in opposite directions, I put one thumb on each wheel… they should not turn independently with heavy pressure.
Unless you apply heavy pressure, you are not duplicating the conditions when the loco is pulling a heavy load. The splines inside the axle casting, when it has split, initially act like a ratchet when they slip, so it’s impossible to notice this visually… the wheels will still turn. I’ve worked on F3’s that of the 8 wheels, only 2 were not slipping.
