I’ve only seen a few of the plastic drives, and they usually did not take long to destruct. Before that, they were quieter. Also I think the metal drives came at the same time or shortly after they started soldering the motors in.
Interesting history, the original design was ok, but the movement of the motors from forwards to reverse spread the “forks” that made the contact with the brush “tabs”… That caused power conduction problems. OK, now solder them to avoid that problem. Oops, now that the motor cannot self-align in the block, the misalignment causes the plastic drives (that kept them quiet) to get chewed up… ok go to metal hex drives…
Now, when you get one, you need to listen for noise, and if so, you have to re-heat the soldered forks to realign the motor to minimize the noise… and the stupid rubber pads… oh, that’s another story.
